Supernait 2 - distortion in the right channel
Posted by: Thorsten_L on 03 October 2018
Hi!
Today after a nice listening session, I realized that the right speaker channel of my Supernait 2 starts to give a "distortion buzz" through the speaker.  It is really quite audible and after a while, it disappears. If I swap the speaker cables, the other speaker now on the right channel, the same occurs.
I attached two audio files.
https://drive.google.com/file/...DdP/view?usp=sharing
https://drive.google.com/file/...otK/view?usp=sharing
I changed nothing in my set up and I cleaned all interconnects (plug/unplug) to no avail.
I have a FritzBox WLAN repeater next to the electricity sockets, but unplugging it does not kill the buzz.
It starts to buzz after about an hour of playing music, either through my TT or my Unity Core...then 10 minutes after the music finished, it disappears and all is quiet again...
The phenomena only started today...
Any helping idea?
Thank you,
Thorsten
Posted on: 03 October 2018 by Adam Zielinski
Most odd... I can’t think of anything that is not an amp malfunctioning....
Possibly a cold solder starting to manifest itself in a pre-amp section?
Perhaps [@mention:36201736971392588] could offer some adivice, before you need to take it for servicing.
Posted on: 04 October 2018 by Huge
This is one of the most odd things I've ever heard.
So, if I read it right...
1   It's a mid to high frequency buzz
2   It never starts until an hour after you start playing music
3   It stops 10 minutes after the music stops.
4   It's independent of source in use (same buzz, same time)
A few additional questions...
A   Does the start of the buzz correspond to the top of the case becoming warm?
B   Does the time before the buzz starts depend on the volume?
C   What speaker cables are you using, and what is the length?
D   If you swap the speaker cables over (right to left) does it stay with the same speaker or move with the amp channel?
I must agree with Adam though, it may be a dry joint that becomes troublesome as the amp warms up (not necessarily in the preamp though!).
Posted on: 04 October 2018 by Adam Zielinski
The only similar thing I've heard was my guitarist's MesaBoogie guitar amp - it turned out to be a cold solder - hence my guesstimate. It was driving both the pre-amp and the power-amp to distortion irrespective of the input signal's strength. And it only appeared when the amp warmed up after 10 min or so.
Posted on: 04 October 2018 by Richard Dane
That sounds like more of a crackle than a buzz.  Probably time to contact your dealer - they can liaise with the distributor or Naim to get an opinion on what it might be.
Posted on: 04 October 2018 by Thorsten_L
Thanks @all
I use 2 x 8m NACA 5.
The crackle stays in the right channel of the amp, meaning it moves to the connected speaker.
This morning I came to my living room and it was a campfire...LOL...really loud crackle. Went to my shop and the same there. They will look into it at MusicLine Germany and gave me an XS2.
I am speechless about how much better my system sounds now. That means that there is more wrong than just the right channel.
And to be honest, now that I think of it, my SN2 ran really really hot...huh... I told them this too. Let's see.
Unfortunately, the warranty ended on August 13th (5 years)...I was hoping NAIM would overlook that time period after spending 25000€+...It's just a bit more than a month...
Posted on: 04 October 2018 by Japtimscarlet
If you bought from a dealer they should support you if only a month ago ...
No. I registered the SN2 and the warranty ran out on August 13 this year. I bought it in 2013, August 13.
