Nap 200DR and Nova
Posted by: fred47 on 04 October 2018
I wonder if there is anything to gain in SQ if I connect a Nap 200 DR to my Uniti Nova? opions very much welcomed.
Posted on: 04 October 2018 by ChrisSU
When I added a 200DR to my Superuniti, it did sound a little better, but to my ears, nowhere near enough to justify the price of the 200. I would expect the same argument to apply even more with the Nova.
If you go for a 200, there is little to be gained in going for the DR version, as the DR spec only applies to its preamp PSU, which you would not be using with a Nova, so a used non-DR version might be worth a try. Or a 250?
Is this an interim measure, after which you will upgrade the rest of your system? I added a 200DR to my SU as the first step towards NDX/282/200, otherwise I would not have bothered.
Posted on: 04 October 2018 by hifi-dog
Isn’t the nova more powerful than 200? The spec for the toroidal transformer is greater in the nova in terms of va and I can’t see the streaming bit using chunks of power
Posted on: 04 October 2018 by Gazza
I added a 250dr then a 300 dr, both improved on the Nova for Prat. But this was an interim step for me , as Chris discussed above, I would probably have happily stayed at a bare Nova or a 272/250.
The Nova and Superuniti are both 80W, as opposed to the 200 at 70W, so you are not getting more power.
Posted on: 04 October 2018 by hungryhalibut
The chap who bought my 250DR added it to his Nova and while there was a difference it wasn’t overwhelming. And that’s a 250 rather than a 200. I wouldn’t do it unless it’s an interim step to something else.
