Connection Advice CD 5XS - n Dac - XS2
Posted by: Hanumike on 05 October 2018
Hi all
I’ve just acquired a second hand mint nDac and intend to try it as the digital to anologue converter for my CD 5XS utilising the 5XS as a transport.
I currently power the CD 5XS via a Flatcap 2 XS and I believe this connection will no longer be required once I utilise the digital out from the cdp ? As the Flatcap also powers the XS2 I intend to use the spare power output to power my Stageline direct which is currently powered via the aux 2 output on the XS2.
I think I need a BNC to BNC digital interconnect (Naim DC1 or otherwise) for the best connection between the cdp and nDac (I assume this should be connected to the BNC coaxial input 1 on the Dac ?) but am a little unsure which input to connect the din out on the Dac to on the XS2.
The Dac manual seems to suggest the Aux 1 input is preferable as this facilitates the remote control link on the Dac but this would require a din to phono cable as the Aux 1 is only a phono input on the XS2. Could I just use a standard Naim 5 pin Din connection cable supplied with the Dac and connect this to the cd input on the XS2 without any loss in sound quality.
Thanks in advance
Posted on: 05 October 2018 by Richard Dane
Yup, using the Naim Din interconnect would be my choice - into the CD input.
When funds permit, then try a Hi-Line.
