Best shoe box pre-amp
Posted by: Dan.S on 10 October 2018
Is there a shoe box sized naim preamp better than the V1? I'm trying to build a second streaming system (uq as streamer+nap100), using a rack specially made for shoe boxes and would like to end up with something better than a SU.
Thank you.
Posted on: 10 October 2018 by Mattnbarns
NAC72 but you'll need a DAC as its strictly analog.  You could stick with the V1 or a Rega Dac.
Posted on: 10 October 2018 by Ardbeg10y
I have a 72/140 and love it. Use a rPI + Chord Mojo as dac.
Beware: the UQ works best on its own - its not guaranteed that UQ as a streamer + dac into a shoebox pre is an upgrade. And thats the beauty of the UQ.
Posted on: 10 October 2018 by HiFiman
72 is probably the best shoe box Naim pre, owned three 72s over the years also owned the 32.5 and 42.
Previously I have used a 72 with a UQ just as a streamer, set the volume on the UQ to around 85 and fed this in line level to the 72.
Also added a Hugo on the digital output of the UQ into the same 72 with great results but in the end I opted for a 272 that is currently in use.
Don't forget if using the NAP100 you will require a HiCap for the 72.
Posted on: 10 October 2018 by hungryhalibut
I’m not sure you will beat the SU all the time the UQ is the source. Would it really make sense to have a UQ, a 72, a Hicap and a 100? Two pairs of different styled boxes. Wouldn’t an SU be better? It would certainly be a lot simpler, with no built in redundancy. These stand alone boxes really don’t make sense as a source, with most of it unused.
Posted on: 10 October 2018 by Dan.S
Would you say 72+HiCap+Uq+Nap100 is better than V1+UQ+Nap100? Is it better than SU?
I don’t know. Neither seem like a very efficient way of going about things. A lot depends on how much you value collecting little boxes. For a  good simple system that wasn’t an SU I’d be looking at a 172/155 or an ND5XS and Nait XS.
hungryhalibut posted:
It would defy the purpose. I'm trying to build a system with half-size boxes (I have a really nice Cyrus Hark rack) but if in the end it cant compete with a SU, I might as well get the SU instead and be done with it!
It’s up to you of course but building a system around a rack seems an odd way of going about things. It’s not that it’s nice looking. An SU on a decent bit of furniture has got to be a better option.
I'd go for the ultimate half size system: unitiserve - dac v1 - nac 72 - hicap - snaxo - hicap - nap 100 / nap 100 into SBLs
Often wondered what active NAP100s would sound like. I seem to recall a forum member who had such a system.
Posted on: 10 October 2018 by JedT
Dan.S posted:
I doubt it personally. I've tried
UQ/102/Hicap/180
UQ/180
SU
SU/180
SU/250
and I'd say the performance gets better down the list (although top 2 was more that I didn't hear enough benefit to keep the 102/Hicap.
The SU power stage is better than the 100 and I believe the DAC is closer in design to the NDAC than the V1 is. But I've never heard a V1 so can't comment on how it compares.
Posted on: 10 October 2018 by Skip
Has anybody tried the Crimson Electronics products?   They truly are shoe box sized.  I have seen them in a couple of dealers.  They sound good but I am wedded to Naim at the moment.  Any comments?
Posted on: 10 October 2018 by Mike Sullivan
I’m interested in this to. I’m running a second system of UC2/NAP100 into Totem Hawks and want more power through the Hawks (I also run a Core to both of my systems). What’s the bettter option, a NAP200 in place of the 100, or maybe the NAIT XS2 (the better headphone stage is attractive), either option running of my UC2 as the streamer/DAC? Can the NAP100 have a second one added to the system, powering each speaker even?
Posted on: 11 October 2018 by Huge
For strictly shoebox width:
72/140
or
Atom
Posted on: 11 October 2018 by JedT
Mike Sullivan posted:
Sell both and buy a SU. Plenty available at <£1800. you'd be upgrading DAC, preamp, power amp and headphone amp. A bargain.
Counter argument would only be if you plan to upgrade to better source / preamp overtime.
Posted on: 11 October 2018 by Dan.S
I think I'll stay with the SU option myself, sell the nice Cyrus Hark and buy a wonderful Quadraspire Wall Shelf instead.
Posted on: 11 October 2018 by Mike Sullivan
JedT posted:
Thanks, I’ll look into that as an option then. I’m in New Zealand, so not sure of the second hand market.
