combining naim with other multiroom devices
Posted by: Geserit on 12 October 2018
Hi,
I think about combining a NOVA or NDX2 with 2 MUSOs for multiroom usage but would love to combine it with a multiroom device/speaker which is suitable in areas with high humidity. Is it possible to implement no naim devices in the naim multiroom setup?
Posted on: 12 October 2018 by ChrisSU
You may be able to do this with Roon, Airplay or Chromecast, but Naim multiroom will only work with Naim streamers.
Posted on: 12 October 2018 by blythe
My understanding is that with the advent of "Airplay2", multi-room with non-Naim devices will be supported. At least that's what I understood but could be wrong..
EDIT: Yes you can https://forums.naimaudio.com/t...-so-and-uniti-ranges
