Speaker advice for Uniti Atom
Posted by: Naim_newbie on 15 October 2018
Hello all,
A year ago my wife and I went out to a local dealership to listen to (and with intent to buy) the Mu-So soundbar. Our LG 5.1 surround radio/cd/dvd home cinema system had died so we needed something new, and the single box with no wires and Naim quality seemed the perfect fit. We were supposed to spend no more than an hour at the store, then go home with the Mu-So. Well...
That hour turned into the entire afternoon plus early evening with the both of us in the listening room and eventually going home with the Uniti Atom and a set of Audio Physic Yara speakers (and cables that cost just as much as the speakers). Our very first "audiophile" set.
Now a year later, we would like to upgrade our speakers. The Yara set works great but the beech wood finish looks entirely out of place in our living room. I would love to hear your recommendations for fitting speakers.
Our criteria:
- Budget around €2500 (or 1250 per unit)
- Floor standing, black
- Sensitivity 89dB or higher
- Minimum power not higher than 20-30W
- Sound at least as good or better than our current Audio Physic Yara speakers (totally subjective, I know)
We still need to go out to listen, but based on specs "on paper" I've put the following speakers on our list:
Golden Ear Triton 5
Focal Aria 926 or 936
Audio Physic Classic 5 or 8
KEF Q950
Would you agree with this list or should I definitely cross some off? Did I miss a brand/type you think I should definitely add to the list?
Thanks!
Posted on: 15 October 2018 by ChrisSU
The problem with speaker recommendations is that the crucial thing is getting them to match you room. The only way to find a good match is to try speakers for yourself, and a good dealer is invaluable for this. As a starting point, I would look for dealers who stock some brands that are popular with other Naim users. This might include Kudos, Neat, Dynaudio and Proac for starters.
Good luck!
Posted on: 15 October 2018 by Naim_newbie
Thank you Chrissu for your advice. I agree that room size and placement are very, very important for speaker sound. Our living room area is a little difficult to work with in regards to speaker placement, so that's a challenge. After the speakers, I will be looking into decorative acoustic treatment next.
I have taken a quick look online on the speaker brands you mentioned. I haven't found a dealer which has 2 or more of these brands in stock - and the dealer where we got our Atom doesn't have any of them. So if I decide to put any of them on my list, it will mean some travelling. Luckily our country is the size of a postage stamp
Yes, it can take some time and effort to find the right speakers. The help of a good dealer is almost as important as the speakers themselves. Alternatively, look for used speakers, try them at home for a while, and you can sell them with little loss if you don’t like them. Speakers often depreciate a lot, so this can be an effective route to take.
Posted on: 16 October 2018 by Naim_newbie
I've looked into the four brands you've mentioned Chrissu. Thanks for bringing them to my attention.
Kudos doesn't look like an option for me - the base model X2 is already close to my max budget and the reviews I've found of it, aren't very good.
The Neat Motive SX2 look interesting but they have low sensitivity (86dB) and the minimum required power is 35W. I doubt the Atom can make these speakers come alive.
Dynaudio - the only set that seem to fit my criteria are the Excite X38 but the reviews I've found make me doubt if they are the right ones in our room.
Proac - To be honest, i like the looks of our Yara set better than any of the Proac.
I will revert back to our dealer and set up some listening appointments.
Posted on: 16 October 2018 by John L F
Like you I was looking for a pair of floor standers to go with my Nova.
listened to most of the usual candidates up to £4,000 before deciding on Dynaudio Special 40s.
Although they are stand mounted they are difficult to beat at their price level of £2,500.
Thank you John, I will look into them. Although they are slightly above my budget
Posted on: 17 October 2018 by blythe
You mention the Kudos X2 but I use my Atom with the Kudos X3 which I'm pretty sure is within your budget (I think they're about £2,200 or less if you fight for a deal).
I find them to be a great match to the Atom and enjoy them.
However, I now kind of wish I'd paid an extra £1000 and bought the Neat Iota Xplorer, which I thought absolutely stunning but somewhat over budget.
I should have re-thought my budget!
Posted on: 18 October 2018 by Huge
I feel that getting speakers to match your room and your personal sound preferences is very much more important than the paper specifications (which, in practice, don't actually tell you very much about how a speaker will sound with any particular system).
Try taking the Atom (and a memory stick with your demo music) around to a load of audio dealers, and see what speakers they come up with!  (One advantage of the Atom is that it's pretty much self-contained and relatively portable!)
Posted on: 18 October 2018 by Peder
???? Naim_Newbie,....Naim Allae,..88-89db,6 ohms.
You can buy them preloved for £ 700:-,cost new around £ 3800:-
An underrated Naim speaker.
/Peder ????
Posted on: 18 October 2018 by hungryhalibut
The Allaes cost around £2,500 when they were discontinued.
Posted on: 18 October 2018 by Naim_newbie
Thanks everyone for your help! I've made an Excel sheet with the speakers we would like to test, with pricing, specs and stores to find them. I have a list of 12 speaker choices across 9 different brands, so that should keep us busy for a while. Saturday is our first appointment to test Golden Ear, Sonus Faber, ELAC and Monitor Audio. Next week we will go to a different store to test Focal, Dynaudio, KEF and Audio Physic. And a third store for the Neat. I am very happy that I've been able to locate all the types in only three stores.
There is one set of speakers in my list which is €1000 above my budget but I'm just so very curious to hear them: Sonus Faber Sonetto III. They look absolutely beautiful.
I will of course update this thread with my findings. Please if you have any more advice for me, I'd love to read it.
hungryhalibut posted:
???? Hungryhaligut,....Ok..In Sweden,they cost around £3800:- the last year they where produced.
It is always good to live in the same country as they are produced in,it always becomes a bit cheaper ????.
In any case,it's not a bad speaker.
I think it was 2013 that they stopped being manufactured.?
/Peder ????
Posted on: 18 October 2018 by Christopher_M
Peder posted:
In any case, [Naim Allaes are] not a bad speaker.
They are bloody excellent speakers. Then again, I'm biased :-)
Christopher_M posted:
Peder posted:
???? Christopher_M,.....I know you are????????.
/Peder????
Posted on: 21 October 2018 by Naim_newbie
Hi everyone,
Yesterday (20 Oct) my wife and I went to our favorite hi-fi store to test new speakers for our Naim Uniti Atom. We spent the entire afternoon there, testing a bunch of different speakers:
  • Golden Ear Triton 5
  • Monitor Audio Gold 300 (I wanted to hear the Silver 300, but they didn't have those)
  • Sonus Faber Sonetto III
Results:
The Monitor Audio definitely needs a bigger amplifier, it was like they were mocking the Atom. We were done testing those within minutes.
The Triton sounded very good at first, but then we noticed that when more instruments were involved in a music piece, the Triton 5 seemed to place a blanket across the vocals.
The Sonus Faber Sonetto III had beautiful vocals, beautiful definition, but with some songs we found a certain harshness in the sound that my wife and I both didn't like.
At this point we became more and more impressed with our Audio Physic Yara set (we brought them along for A-B testing). Perhaps the Triton 5 and Sonetto III are too complex for the Atom?
So then we tried the Sonus Faber Sonetto II, a monitor instead of a standing speaker. As soon as the first song started, my wife and I looked at each other like "wow!". Vocals were beautiful, definition so beautiful, but no harshness and no blankets anywhere. We tried all kinds of genres: Classical, Rock, Metal, Gospel, Jazz... the Atom and Sonetto II worked like a fantastic team and handled everything beautifully.
We were also invited to listen to the Sonetto V in combination with the Naim Uniti Nova. Now, these are a match made in heaven. In fact the V sounded much like you'd expect from a €10k priced speaker. We were very, very impressed. They then set up the Sonetto III speakers with the Nova. Again, disappointment. It was clear that the Nova is a much better match with the Sonetto III than the Atom, but the V sounded so much better than the III it was mindboggling.
Soon we will be able to test the Sonus Faber Sonetto II in our livingroom, we can't wait!
