Delete tracks Tidal playlist
Posted by: Stover on 16 October 2018
If I delete a track from a playlist (collected tracks over time) it won't dissapear from the playlist. Any suggestion, which I suspect is obvious ????
Stover
Posted on: 16 October 2018 by ChrisSU
Have you tried it in the Tidal app rather than the Naim app?
Posted on: 16 October 2018 by Guinnless
If you delete using the Naim App you have to move away from that view and come back again to refresh.  So for example select Tidal - Genres and then select Tidal - My Music and the list will have then refreshed.
Posted on: 16 October 2018 by Stover
ChrisSU posted:
No, bit tried now and it seems to work perfectly, thanks Chris
Stover
Guinnless posted:
Wow, seems to work that also. I have tried to leave Tidal in the app and then go back, but no luck. If I delete, change input from Tidal to iRadio and then back it seems to refresh nicely.
Thanks, Stover
