Uniticore and Andriod Naim app repeating tracks repeatedly
Posted by: guyt on 21 October 2018
Good afternoon,
New poster and recent Uniticore purchaser who needs some advice and opinions
I bought a Huawei Media Pad to run the Naim app.I use the Core as a music player via the BNC cable into DAC;no streaming involved.
My problem is that when I play any album,tracks will frequently repeat themselves,usually only once and then move on.I installed the app on my wife's iPad and that just works perfectly.
Has anyone else experienced this problem on any Android device? and suggest any solution before I spring for an iPad of my own
Many thanks in anticipation
Posted on: 21 October 2018 by ChrisSU
If it was doing this all the rime, I would suspect that you had accidentally hit the repeat button, which is quite easy to do without noticing. If it’s happening erratically perhaps it’s something else.
Posted on: 21 October 2018 by David Hendon
I don't use Android myself but as a beta tester I read a lot of postings about all of the software/firmware and I don't ever remember seeing anyone have this problem, except in the situation that Chris mentions. If it were a feature, even occasionally, of the Android app, I would expect to have heard that Naim was working on it.
Maybe best thing would be to phone Naim support and see whether they have met this problem before.
best
Posted on: 21 October 2018 by Japtimscarlet
Beta tester here too on the core / android
Yes mine does the double stutter and repeat thing...it is annoying for sure
Also when you try to jump tracks it often circles round and replays the same track again
