Multiroom playback (SU+UQ2) no longer works
Posted by: El_Soldado on 30 October 2018
I have used Multiroom playback reasonably regularly between a SU and UQ2, both on the current firmware, with no issues.
In the last few days I get the following message: "A Maximum of 0 Multiroom Clients is supported".
Any guesses as to what's wrong?  I have power cycled both streamers.
Posted on: 30 October 2018 by ChrisSU
A couple of things to try:
Are you trying to stream a hi-res format that Naim multiroom will not support? (Although I’m sure RTE1 should be OK here!)
When you restart, do your whole network, turning the router back on first.
Posted on: 08 November 2018 by El_Soldado
Real life intervened!  Still no joy, I power cycled everything (router, switch, two streamers).  Tempted to try a factory reset on both, but nothing has changed in my config.
