Ovators S400
Posted by: Stevek on 31 October 2018
Hi.  Yes it's me again, I have moved my speakers, slightly further away from listening position and wider apart, spend a lot of time making sure they were EXACTLY level which took a,while to do, what a difference well worth the effort, a massive improvement.
Steve
Posted on: 31 October 2018 by Christopher_M
Thumbs up.
C.
Posted on: 31 October 2018 by Peder
Stevek posted:
 Steve
???? STEVEK,...."Attention To Detail",is the most important thing in a music-system installation.
Unfortunately,..many people do not understand that,just look in the System-Pic thread.
Fun to hear,good luck.!
/Peder ????
Posted on: 31 October 2018 by Ardbeg10y
Peder posted:
Stevek posted:
 Steve
/Peder ????
We are waiting for your contribution, Peder! - or have I missed it?
Posted on: 01 November 2018 by Adam Zielinski
Excellent - good to hear they perform up to your expectations now.
If you feell like experimenting with another position in the future, mark their current spot with a bit of masking tape before you move them.
Posted on: 01 November 2018 by joerand
Stevek posted:
How exactly does 'EXACTLY level' differ from 'level'?
Stevek posted:
Did you consider moving your listening position? If you're listening from a chair it's probably less effort to move than two speakers, especially given the exact leveling and all.
