Unity Core Music Store back-up
Posted by: Robert Burgess on 31 October 2018
Hi - I have my Uniti Core WAVE music store files backed-up to a portable SSD via the Core UBS front connection. I've followed the back-up procedures using the Naim app. If I ever need to restore the files from the back-up (following the restore steps in the Naim app), will metadata changes I've made to the original WAVE music store files be recovered (album art, etc.)? Afraid I couldn't find a clear answer on a Forum search. Thanks as always for your input.
Posted on: 01 November 2018 by Rich 1
I think I'm right in saying that as long as your back up was taken after you altered the metadata (using the Naim app) and as long as you also used the app to make the back up, which it seems you have, all changes you made will be restored, including play lists. This is also true for any music in the Downloads folder. Rich
Posted on: 01 November 2018 by David Hendon
And I too think Rich is right in saying that.....
best
Posted on: 01 November 2018 by Robert Burgess
I was hoping that was the case. Thanks!
