sonictransporter with better power supply for roon
Posted by: T38.45 on 31 October 2018
...what do you think? does it make sense to run an sonictransporter i5 with better -means linear psu- for roon? the standard psu is a cheap small, black box (standard) with a 12V connector!
thx! Ralf
Posted on: 31 October 2018 by SimonPeterArnold
If your direct connecting the sonic transporter  to the DAC then it might help, if not your likely wasting your money. Spend it one something more worth while.
Posted on: 31 October 2018 by T38.45
Ok...thanks!
Posted on: 03 November 2018 by Echolane
T38.45 posted:
thx! Ralf
Trying to understand your request because I’ve been somewhat interested in buying a Sonic Transporter.
Are you asking if the audio from the Sonic Transporter would be improved by buying a linear power supply for it?
Posted on: 04 November 2018 by T38.45
Echolane, right....I was asking if this dedicated PsU would make sense here SQ wise. The sonictransporter is a pretty nice box! I‘m running the i5 which does it for me (no DSP etc.), the nucleus/roon is too expensive for me....
