NDX system integration.
Posted by: james n on 04 September 2011
James
Hi James -
Given the Nait XS has a "Remote In" socket, and given that the NDX manual says:
"...With System Automation enabled and an NDX Remote Out socket connected to the Remote In socket of a Naim preamplifier (or integrated amplifier), CD player or the Naim DAC, the NDX handset and n-Stream App can provide system-wide control..."
I would be very surprised to learn that it did not work!
Hook
http://www.naimaudio.com/userf...ystem_automation.pdf
Very neat !
James
James, I have the NDX connected up to the RC5 socket on my NAC552. It all works perfectly! Nice to be able to control the system through the n-stream app on the iphone.
Now if I could only find a way for it to turn a record over...
System Automation works a treat but where's recording/headphones and mono-selection?!
I hate the fact that I still need to have the ugly-ass narcom remote(s) lying around just for those ![]()
James
+1. And if Naim also adds the Disp button too, then I could easily park my Narcom in a drawer.
But it has been quite a while since any N-Stream improvement. Makes me wonder if Naim thinks they are at job done. Or perhaps they have turned their attention to a new, unified interface (never did understand the artificial divide between Stream and Serve)...
Hook
What cable do I need to connect NDX and Supernait?
If I am understanding this thread correctly, this will then give me volume control on the App - correct?
And yes, I can tell left from right........
You need a 3.5mm to 3.5mm lead, stereo or mono will do.
Frank.
All opinions are my own and do not reflect the opinion of any organisations I work for, except where this is stated explicitly.
