NDX 2 Internet Radio
Posted by: Naimtec on 06 November 2018
Do any of the of the NDX2 or Nd555 owners know how to stop or pause an internet radio station. Previously on my Ndx I used the stop button in the app but this seems to have disappeared with the NDX2. The only way I have found is to select another station or change to server and select a track.
Posted on: 06 November 2018 by Pcd
On the ND555 you can put it into standby using the remote pressing the standby again brings back the Iradio I assume the NDX2 would be much the same.
Posted on: 06 November 2018 by ChrisSU
On the new streaming platform, also including the Unitis, the Stop Stream button has been omitted, either by accident or design, I don't know which. It is irritating to have to navigate to another input, play something, then stop it, in order to silence iRadio, but that's the way it is. I suggest you contact Naim with a request to get it reinstated, as if enough of us pester them about it, they might one day deal with it.
