Which Wireless Speaker under £300 for streaming?
Posted by: iliria on 07 November 2018
Looking to buy a wireless pseaker for my son to use in his bedroom. It will mainly be used to stream from Spotify. There is a myriad of offerings out there. Which one would be recommended please?
Posted on: 07 November 2018 by blythe
At that price range, I'd say Sonos Play 3.
It sounds OK, does everything, easy interface, reliable.
I believe it also supports Airplay 2 so should (eventually) play nicely with your Nova if I'm not mistaken.
However, don't expect Muso-QB performance!
Posted on: 07 November 2018 by Mercky
The Audio Pro Addon range get good reviews
Posted on: 07 November 2018 by iliria
blythe posted:
It sounds like a good option especially since it is quite a bit less than the £300 max price I'm applying. I know that Muso-QB has received some very good reviews however its price is quite prohibitive as i dont fancy spending £600+ on a wireless speaker. Also, its power is going to be wasted in the small room in which it will be used. Well, truth be told, I dont particularly fancy my son blasting some of that horrible grime and rap music stuff in the house
Posted on: 07 November 2018 by Dungassin
Not sure why 'too much power for a small room' is a problem.  I'm using my NAP300DR in my 13 x 8 foot study!
Posted on: 07 November 2018 by hoejfed
B&W A5/A7 You Can find it used at a good Price , but it is only airplay 1. However it sounds good in a small room, (i have 2 A5 standing as dust-collectors, in Denmark )
Dungassin posted:
Oh no, I didnt mean it's a problem but rather it would be wasted for what it is intended to be used.
Anyone know if Sonos Play 3 is better than Bluesound Flex 2i? The latter seems to be a winner in regards to connectivity however I'm not sure  about sound quality?
I heard a Play 3 at the weekend in a friends gaff, not that impressed to be honest but maybe I expected too much, the sonos app seems good though
Posted on: 08 November 2018 by Dungassin
iliria posted:
Dungassin posted:
I guessed that.  However, every upgrade I have made in my small study is easily audible.  I would get a NAP 500DR, but I don't have the room!  SWMBO claims the living room is 'hers', so my hifi was banished to my study.
Posted on: 08 November 2018 by SimonPeterArnold
BlueSound speakers are pretty good and cover all the bases and more.
Posted on: 08 November 2018 by iliria
Dungassin posted:
To be honest the type of music that my son listens sounds like noise to me. In which case the least one can hear the better. Thankfully I am safe on the SWMBO side. Everytime she tries to give an opinion about the music side of things she has been met by a flat "Tough!" response from me and eventually she has learned not to give an opinion aymore.I'm half joking of course. I think my partner knows that I dislike multiple boxes and tons of wires and tend to prefer minimalistic so she is happy with my choices. She was a bit horrified when she heard the cost of the Nova but soon calmed down after she heard the sound coming from it (and I've got to upgrade the speakers yet)
I have limited the upgrade habit to the lounge area where most of the listening is done and even there I have limits. In other rooms I am satisfied to limit the experience to a "reasonably good for the price" piece of equipment. So, I have set the limit to £300 and am trying to find the best piece of equipment within that price.
SimonPeterArnold posted:
Simon, have you had a chance to compare Bluesound to the Sonos?
Posted on: 09 November 2018 by SimonPeterArnold
Not directly but have heard Sonos at a friends house. It was ok but nothing great. Bluesound come from more of a hifi background being part of NAD so have a bit more pedigree but some prefer Sonos. Both are pretty much plug and play. The advantage with the Bluesound Pulse Flex is out can get a battery pack so it can be used outside, Sonos can't do this, big mistake in my eyes, ears.
Posted on: 09 November 2018 by David
 My son has a Libratone zip,  pretty good for the size and price, rechargeable battery and very portable.
works well for him
Posted on: 09 November 2018 by ChrisG
I much  prefer the sound of the Sonos Play One or whatever it's called now over the Play 3. The sound is mono but you can always add another Play One to make it stereo and that will certainly beat a Play 3 in my opinion. I personally think that the Play 3 is the weakest of all the Sonos powered speakers.
The Sonos app is second to none and the set up is a dream.
Posted on: 09 November 2018 by Mercky
ChrisG posted:
Yes I’d agree with that, a wine bar near me has multiple play ones strung up around the ceiling and they sound pretty nice, albeit just background music but there’s nice bass coming through  all the same
Posted on: 09 November 2018 by TK421
ChrisG posted:
This is a great idea and £2.00 under budget.
Sonos Play:1 without voice control gizmo are £149.00.  Two of these and jobs a good un! Like proper stereo and all that.
I would have been chuffed to bits 35 years ago if my old man had turned up one night with these.
Posted on: 09 November 2018 by Simon-in-Suffolk
I quite enjoy my Sonos1.. it goes quite loud and packs a punch..and it can compensate for different positions with its DSP, albeit you need to get it sounding like Dr Who’s TARDIS and wave  your iPad or iPhone around the room recording it... But to be fair it’s not at all Hi-Fi..detail, timing  and all that is very absent...
Absolutely Simon, but at £150-199 I think it's s a bit of a steal and if as stated he's mainly streaming Spotify, it'll do the job very nicely and it's pretty bullet proof.
Posted on: 10 November 2018 by Simon-in-Suffolk
Don’t disagree, and playing lossless Qobuz through it sounds even better.. certainly the Sonos is good enough to appreciate the difference between Spotify and Qobuz.
Posted on: 10 November 2018 by james n
We have a few Sonos 1 speakers dotted around the house. Great little speaker for the money and pretty decent SQ to boot for background listening. Combined with a Connect running into the main Hi-Fi it's good for whole house music / radio.
I'm sure your lad will be very happy with a Sonos 1. It really is just plug and play and the control app is nice to use too.
