Speaker Dilemma
Posted by: dalmatian on 10 November 2018
My current system is a Uniti Nova into Naim Allaes my room is 4m wide and 6m long I have solid walls and solid floors. The speakers fire down the length of the room, I can have them about 250mm from the rear wall and 750mm from the side walls, there is a sideboard in between the speakers. I do like the sound of the Allaes but as always I’d like “more”. I’d like tighter bass more realistic voices and a bit more 3 dimensional sound, with this in mind I went to my dealers to audition some speakers and came away confused.
I have tried a pair of Ovator s400 s hoping they’d give me what the Allaes have but “more” , they really didn’t suit me/my room so I moved them on.
I have about £3000 to spend so I listened to Focal Aria 926, PMC Twenty Five 23s and  24s and B W something! I liked the bass on the Focals but not the treble, I liked the way voices were portrayed on the PMCs but didn’t like the bass and the BWs just sounded flat. Having spoken to the dealer we came to the conclusion that what I’m looking for isn’t available for £3000 and I really need to double the figure!
When I returned home I played the same tracks I used in the demo and the Allaes blew them all away, they are great speakers, so my question is to get what I’m looking for I should buy pre loved, a quick look on eBay and I found Focal Electra 1028 be, Naim SL2, and Kudos Super 20a’s. My dealer recommended the Focal Electra range (but he doesn’t stock them), I do like a sparkling top end and realistic 3D voices. Also what about stand mount speakers? What about SBLs? God I’m confused! Your thoughts would be appreciated.
Nick
Posted on: 10 November 2018 by Mercky
Check out the Spendor A4 or A7, I’m running the 4’s with a Nova and it’s pretty darn good, borrowing a set of 7’s today hopefully to see if they can give me a bit more scale. Spendors are fab for midrange presence and they really shine with vocals so you might like them, in budget too.
Posted on: 10 November 2018 by MDS
Hi Nick
I see from your profile that you're based in Kingswood, England. If that's Kingwood in Surrey I'm pretty close and you'd be welcome to come and hear how a pair of Electra 1028be perform.
M
Posted on: 10 November 2018 by hungryhalibut
Before spending any money whatsoever, I’d try removing the sideboard. Give the Allaes some space. You might be surprised.
Posted on: 10 November 2018 by Timmo1341
The ribbon tweeter of the ProAc D20r is superb, and the bass is as tight as a..........! I ran a pair for 2 years with a SuperUniti and loved the result. Pretty impressive sound stage as well. The downward firing bass port makes positioning fairly straightforward. Worth an audition if you have a local dealer.
Posted on: 10 November 2018 by dalmatian
MDS posted:
Hi Nick
M
Sadly I’m in Kingswood Bristol, thanks for the offer. What are your impressions of the Focals, have they got the “sparkle” ?
Nick
Ah. Ok, Nick. I’m a big fan of Focal speakers and have heard quite a few.
The 1028’s have scale, and the beryrillium tweeter certainly gives them sparkle, as it does on the stand mount 1008 and the other speaker ranges where it is used eg Kanta, Sopra and above.
mike
dalmatian posted:
MDS posted:
Hi Nick
M
Nick
Posted on: 10 November 2018 by yeti42
I thought 250mm seemed rather a large gap but I’ve just measured the ones in my spare room and they’re 225mm and I know the care I had to take to get them right (220mm gave a one not bass) so presumably you’ve done the same, if quoting to the nearest mm is any indication. Allaes are about the right level for a Nova and beyond but are they still in good nick? There was a thread recently about the foam in the bass driver box perishing. mine is still OK so they haven’t all gone yet but easy to check , I think a replacement was identified in that thread.
yeti42 posted:
They are in near mint condition inside and out, when I first bought them I tried various distances from the side and rear walls and have them sounding good, they are superb speakers. No doubt they would be better without the sideboard in between them (they are 5” away from the sideboard) but room constraints dictate the positioning, I’m really after speakers that will give me the improvements within the constraints I have.
Nick
I’d try them either without the sideboard or, if that really is impossible, firing across the room. You won’t know until you try. It’s all very well getting recommendations but if you are going to put them either side of a sideboard you are not going to achieve the three dimensional sound you seek. No speaker is immune to the laws of physics.
They are in the only position they can be in sadly, there must be speakers that will work within my limitations.
Nick
Posted on: 10 November 2018 by Huge
I have friends in Kingswood, Bristol, I could come and bring my microphone and laptop and measure the acoustic properties of your room; then you can really see where the acoustic problems lie.  You may be able to fix the problems with moving furniture or adding some absorbers or diffusers.
Posted on: 10 November 2018 by Gazza
Dalmatian, there is a really nice offer from a very nice and clever person who is steeped in knowledge on this subject. I would personally take up the offer by Huge, just to have a lovely chat.
It is a very nice offer, much appreciated, I am going to try moving the sideboard tomorrow and see what gains I get if any and reassess from there.
Nick
Posted on: 10 November 2018 by tonyi
dalmatian posted:
yeti42 posted:
Nick
Can you see the internal foam of the mid/bass box without removing the speaker unit or have you removed the speaker to confirm that the foam is in mint condition. It would be helpful to Allae owners to know the size and shape of the foam for replacement.  At the moment, the foam is available but I don't know for how long. I have replaced my SBL foam with the correct specs of 80 ppl and shape.
I have looked into the bass unit box without taking the driver out, it’s all there and looks in great condition.
Nick
Posted on: 10 November 2018 by Guinnless
What source and amp was on the demo system?
I was over the moon with my Spendor A7s which were better in every way than Credos that have the same drive units as your Allaes.
As others have said get rid of the sideboard.
Posted on: 10 November 2018 by seakayaker
I went to a demo the other night and they had the Spendor A7 speakers set up with the NOVA and it was a very nice pairing. They would be worth a demo with your NOVA.....
Posted on: 10 November 2018 by Peder
???? Dalmatian,....As others have said,..Remove your sideboard.
Once you have done that,it is very possible that you may have to make a small "tunning" of your Allae.
This is because you are changing the acoustic conditions a little.
If you use a systematic tunning-method,then you will ultimately be able to hear a difference of just 1-2mm movement of your Allae.
Also,consider this,..as both me,others and even Darke Bear have written about earlier....
If you are not knowledgeable yourself,..or do not have the right tools.
Then let a savvy trader or friend perform this below described,..this makes a big difference musically.
If this hasn't been done in the past at some point,it might be a reason you've started looking for other speakers.
◾Torque Draw all screws,bolts in your speakers,...speaker-drivers,tripods,etc.
Naim,..or your dealer has the real Nm-values you need.
But as I said,if you've never done this,..or do not have the right tools,..or feel uncertain. Let a savvy trader,or savvy hifi-friend perform this.
Note: This makes a bigger difference than most people think.
Also keep in mind that your spike's on your Allae should be as short as possible,in other words,as far as screwed in the tripod as possible.
And if you don't have Naim Fraim Chips under your Allae,borrow home 8 pieces from your dealer and try it out.
But remember,your Allae has to stand "Rock Solid" on these Naim Fraim Chips,..In other words,no rattling.
This takes time to perform,just finding the right position on your speakers takes at least a few weeks..So do not stress.
The result is well worth the effort.!
With these measures performed,..as I described in my post,well then you may not need to look for new speakers ????.
Good luck....
Peder ????
Good advice from Peder.
A  couple of caveats though. ????  whilst accurate positioning is important it doesn't need to be millimetre perfect. ???? you're not assembling a Cosworth DFV!
Also be careful of torquing up bolts on old cabinets. It may be fine of course but you could issues. My Credos tightened up fine with a noticeable improvement, but another chap on here had an incident with his SL2s.
I have tightened the bolts not long ago, I am an Aerospace engineer and have access to the correct tools so they are fine. I will be moving the sideboard tomorrow to see if it makes a difference and rechecking the set up of the speakers, I’ll report back with my observation when done.
Nick
Posted on: 10 November 2018 by John L F
I have a Nova in a 7mx5m room and paired them with Dynaudio Special 40s.
Excellent sound and well worth an audition.
Posted on: 13 November 2018 by Christopher_M
What's the sideboard latest?
Posted on: 13 November 2018 by dalmatian
Christopher_M posted:
Sorry, meant to update the thread. Moved the sideboard from between the speakers had a good listen and there’s a definate improvement, bass is a bit tighter and the soundstage a bit bigger, not a massive difference but a move in the right direction. I’ve realised I do like the “sound” of the Allaes as opposed to the other speakers I demonstrated, I’m wondering what SBLs’ will be like as most people seem to rate them higher than the Allaes?
Nick
Posted on: 13 November 2018 by hungryhalibut
I really wouldn’t recommend SBLs with ‘just’ a Nova, as they are more at home with more elevated systems. I think they are hugely better than the Allae, but are more system dependent. But that doesn’t mean that the Allaes aren’t great speakers, because they are.
Posted on: 13 November 2018 by glasnaim
The SBL's certainly seem to be cheap speakers to buy, quite a few recently on fleabay, they may sound good but they sure have had a good thrashing with an ugly stick.
