Q Acoustics concept 40
Posted by: t@rmac on 11 November 2018
Hi,
Nac 272+ Nap 200 ( 25 mq2  room )  .........the concept 40 are a good choice ?  Any feedback with Naim  ?
Too much cheap  ?
Posted on: 11 November 2018 by Iver van de Zand
That system deserves the Concept 500. I have extensively auditioned those, and they are very good value for money
Posted on: 11 November 2018 by SamC
Used them with 282/250 for a while. Upgraded to B&W 804s. Which are better, but certainly not 10 times better...  I think you’d be fine with the Concept 40s and saving the £000s.
Posted on: 11 November 2018 by t@rmac
thanks ,
will go for an audition
Posted on: 11 November 2018 by Bob the Builder
I owned the standmounted Concept 20 when they first came out and they where a fantastic little speaker used them with a matching Q Acoustics sub driven by UQ2.  I believe Q Acoustics was set up by some ex Mission engineers so they know what they are doing at this end of the speaker market the Concept 40s are excellent vfm.
