New Speaker Cable Advice Needed
Posted by: Docv on 14 November 2018
I’m planning for new speaker cable to connect my olive 52/250 to my KEF Reference II (c2000 vintage).
Currently using the cable I obtained when I purchased the speakers...QED silver anniversary: it’s biwired and I want to go back to single wire so I will also need a “jumper”.
Thank you for advice/ suggestions.
Posted on: 14 November 2018 by Matteo
I suspect that the replies will be "Nac A5" or "Nac A4".
If your budget is limited, I would say Linn K20.
M.
Posted on: 14 November 2018 by ChrisSU
.......and solder F-connections on them rather than separate jumpers.
Posted on: 15 November 2018 by Klout10
If you do qa quick forum search, you'll find many topics about speaker cables.
Many people stick with the 'good old' NACA5 ...
Posted on: 17 November 2018 by Docv
I’ve bought some NACA5 from eBay
...any photos of soldered “f connections” available.
thanks
stewart
Posted on: 17 November 2018 by ChrisSU
Do a Google image search for ‘NACA5 f connection’ and you will see some pics.
Thanks Chrissu
will need to mug up on my soldering skills
Posted on: 17 November 2018 by rohan
Just moved to vertere d5 from naca5 much tightet bass and better mids...used to be skeptical about the impact cables would make but in my setup it has made an obvious difference. Anout gbp350 for 3metre
Posted on: 30 November 2018 by Docv
NACA5 up and running....whole system benefiting from recent upgrade in power supply side as well as these cables...back to enjoying the music
