iPhone to naimuniti through usb
Posted by: balma01 on 14 November 2018
I’m streaming usb music stored on my iPhone to a naimuniti ( first model) using the usb front input. It works! How to stream from an app like soundcloud or amazon music using the usb connection ?
Posted on: 14 November 2018 by ChrisSU
Non-Apple apps often won’t play into the USB input. If you start playing something from iTunes, then switch to the app that you want, that usually fools the phone into continuing to play through the USB.
Posted on: 14 November 2018 by balma01
Thanks. Is it possibile to do it using an android device?
Posted on: 15 November 2018 by ChrisSU
No, I believe it’s iOS only. The easy option if you want to do this would be a Chromecast Audio into the optical input on the back of your Uniti.
