Naim 202 controlling volume
Posted by: Johnboy on 16 November 2018
Just a simple question, I am looking to buy a NAC202 to go with my NAP200.
The question is, is it a requirement to buy the NAPSC for the remote volume control to function from the NARCOM remote?
Or will the volume control function without one?
Thanks in advance.
John
Posted on: 16 November 2018 by Richard Dane
John, you don't need the NAPSC, it's a nice little cost-effective upgrade though.  Just make sure you have the link plugs for the NAC202 as they will need to be in place when not using either NAPSC or Hicap.
Posted on: 16 November 2018 by Johnboy
Many thanks for your speedy reply, Richard.
Posted on: 17 November 2018 by Mike Hughes
You’ll want the NAPSC regardless.
Posted on: 17 November 2018 by Japtimscarlet
For approx £80 to £100 used a Napsc is a must have ...and will increase the value of your 202 come upgrade time ..
Posted on: 21 November 2018 by Johnboy
We have just had a home demo of both a NAPSC and a HiCap DR.
They sounded so good we have gone for both options.
