mb100 with SN2
Posted by: Rbt1 on 21 November 2018
Maybe someone has tried or knows if it possible. I have the possiblity to borrow a pair of TP mb100. My Naim amp is a SN2 is it possible to bypass the amp in the SN2 and use only the pre section with the MB100s? I would like to know the sound, I am very happy with my kit now but it just to try.
Posted on: 21 November 2018 by ChrisSU
Yes, you can run a non-Naim power amp with a Naim preamp, including the Supernait preamp. You’ll need to get suitable DIN to RCA cables, although I wonder if you could also use the Supernait RCA sub out.
Posted on: 22 November 2018 by Rbt1
thanks Chrissu for the info. That’s my problem where do i plug the din cable, because in the naim wiring pdf it is not so clear. That’s an interesting idea to run the amps from the  sn2 sub out but wouldn’t I have problems with the gain?
Posted on: 22 November 2018 by ChrisSU
Probably best to just use the pre out of the SN2 with a 4 pin DIN to 2xRCA lead, but the sub out is post volume control, so it should work too. Have a look at the connections guide for more pics (google ‘Naim connections guide’ and you’ll find it.)
Posted on: 23 November 2018 by Rbt1
So if I understand the connection guide I connect a 4pin to RCA from the out put labeled nap power amp in.. Sorry I’m such a beginner I bought my kit used several years ago it’s my first step into real HiFi. It’s such a pleasure to listen music now. My last question; My logic tells me that if I go with the 4pin from the 2 Monoblocks the signal is bypassing the amp in the SN2 and using just the pre in the SN2 correct . If I use the sub out am I getting the full signal? Or just the lowest frequencies? And again thank you For sharing your knowledge
Posted on: 23 November 2018 by ChrisSU
The sub out does not filter out the high frequencies, the sub normally does that itself, so if you prefer to use RCAs, I think that would work. Naim prefer DIN connections, which you would take from the preamp output.
