Muso app
Posted by: David-welsh on 22 November 2018
new purchaser if the naim muso , great sound system but the app, not impressed. I am hoping others can give me advice what am i getting wrong.
is there any way of changing the input options on the front page. I want tidal and optical inputs on frront page with usb and spotify relegated to the 2nd / slide page?
Posted on: 22 November 2018 by hungryhalibut
Regrettably, that is not possible.
Posted on: 22 November 2018 by ChrisSU
In case you haven’t yet discovered it, you can disable any inputs you don’t use so that they don’t clutter up the home screen, although you can’t move them around. (At least I presume you can, I’m guessing the Muso is the same as other Naim streamers in this respect- HH will correct me if I’m wrong.)
Nope, you can’t do that. You are stuck with them all. Quite why, I have no idea.
Posted on: 22 November 2018 by GregWPGibbs
Strange how certain options are available on the Muso, but not Uniti and vice-versa using the same app⁉️
Posted on: 22 November 2018 by David Hendon
GregWPGibbs posted:
It’s because the app controls the Naim product and what you can do with it depends on the hardware and firmware in the product.
best
Posted on: 22 November 2018 by David-welsh
Expensive hi fi but the app is a bit of a dog’s breakfast. Shame the poor app lets down the overall kit.
No video available that a new user can watch and learn. Naim customer service too busy dealing with issues, i suspect many due to new users like me asking for help!
still havent found anyway of rearrang8ng the icons on the app, tried drag and drop but no success. Like an 1980s fixed menu on a screen.
Posted on: 22 November 2018 by Mercky
disable the unused inputs and the ones you want should then appear on the first page, you cant drag n drop. You can rearrange your favorite radio stations though which annoyingly you cant on the Unitis. I dont find the app on ios to be that bad at all - a few annoying things which are more functionality firmware issues rather then the app, certainly not 1980's esque
David-welsh posted
That’s because there isn’t one. It’s hardly the end of the world though.
Mercky posted:
You cannot do this on a mu-so.
hungryhalibut posted:
Mercky posted:
ah ok, its a while since I've had mine, so yes, a bit annoying then i guess but not the end of the world as you say
