New Muso Qb
Posted by: Kermit on 24 November 2018
Just bought new Qb, lights around volume work and can be dimmed, but base light not working at all. I left  Naim a couple of years ago due to problems with their products and it seems as if things are the same, or am I missing something? Thanks
Posted on: 24 November 2018 by Guinnless
Return it?
Posted on: 24 November 2018 by Richard Dane
Kermit, most unfortunate, but I guess things can sometimes go wrong.  Best get in touch with your retailer.  I'm sure they will sort things out for you.
Posted on: 24 November 2018 by Loki
Dealer time! Check settings though, as base light can be controlled from app. Have you turned it off?!
