Synology NAS Not visible to MUSO QB Over Wifi
Posted by: NeilGP on 27 November 2018
Hi all,
In the process of setting up my my synology NAS server in anticipation of my ND5 XS2 arriving next week.  While doing this I've also purchased a MUSO QB for upstairs. Everything is working fine apart from that when I select UPnP on the Qb, nothing!  Nada...  I just get a spinning wheel.
The mystery deepens when I tell you that my Mac mini in the next room on the same wifi network has no difficulty seeing and loading the the NAS drives.
I've got Media Server set up on the NAS and also the NAS is seeing the QB itself when I check the connected devices list in Media Server...
So.... Any thoughts or ideas from anybody?
(Wifi is Google wifi. Addition info is that I have a Denon network player on the hardwired LAN with the NAS and that can see the NAS and play tracks from it without any problems.)
Posted on: 27 November 2018 by hungryhalibut
You’ll need to connect the Qb to the network with a wire.
Posted on: 27 November 2018 by Guinnless
hungryhalibut posted:
It should see the Media Server via wireless though.
It may be worth running through the Qb setup again.
