Move from Naim Nait 5si to Rotel RA-1570
Posted by: RaghuV on 28 November 2018
I have been running Harbeth 30.1s with a Naim Nait 5si and a very budget Musical Fidelity V-90 DAC.
From a spell of upgraditis, I bought a used Rotel RA-1570 with a built in DAC and 120 W per channel into 8 ohms.
I set up the amp and have been listening to it for the last 2 hours wondering if I made a horrible mistake. The music seems lifeless and dull.
Maybe a mistake? Should I wait for a while? Will things improve with age?
The Rotel has about 200 hours on it. In agony!
Posted on: 28 November 2018 by RaceTripper
I would just upgade it to a Naim Nait 5si and call it a day.
Posted on: 28 November 2018 by cdboy
As you have heard it I think you may have answered your own question.
Posted on: 28 November 2018 by RaghuV
I used my Musical Fidelity V-90 DAC to feed the Rotel instead of the Rotel’s internal DAC and the MF DAC outperforms the Rotel’s built-in DAC!
And I think I am still missing the Naim sound.
I haven’t sold the Naim. I may be heading back to familiar pastures!
Posted on: 28 November 2018 by blythe
I am not surprised.
Just reconnected the Naim! Now to figure out how to get rid of the Rotel.
RaceTripper posted:
Just did!
Posted on: 29 November 2018 by Innocent Bystander
I’m curious: What made you think the Rotel would be an upgrade?
And what originally made you buy a Naim amp rather than another brand? If it was the ‘Naim sound’, why are you surprised that the Rotel sounds different?
Posted on: 29 November 2018 by Stephen Tate
I think that the OP may have discovered that MORE watts does not necessarily bring with it better or a more enjoyable performance. If not already done so; I would upgrade the NAIT 5Si with Naim's own NAC A5 cables made up with the 'right angled' plugs by someone who is very experienced with such terminations.
Posted on: 29 November 2018 by Got Hi-Fi?
I came from NAD/ROTEL & Marantz to Naim. The former 3 basically have similar sound signatures, which are dead on with what you described your Rotel as. I thought they sounded good ... until I heard Naim.
Posted on: 29 November 2018 by ricsimas
Innocent Bystander posted:
Maybe he spent too much time hearing the Harbeth spiel that all amps sound the same?
Posted on: 30 November 2018 by Daniel H.
I am not surprised by the result!
Posted on: 30 November 2018 by Robiwan
reconnect the Naim and you hear that it sounds small, shut in and dark.
Posted on: 01 December 2018 by Stephen Tate
Daniel H. posted:
Indeed. The NAIT 5Si is an exceptional amp when partnered with an exceptional source.
Posted on: 01 December 2018 by Iconoclast
Robiwan posted:
What sounds small, shut in and dark?
He probably read all the good reviews or saw some B&W demo clips on YouTube that use Rotel amps (both belonging to the same company). While the Naim forums logically tend to promote Naim gear there's a lot of information to out there that says otherwise. It's difficult to know who's opinion to trust.
Posted on: 01 December 2018 by Innocent Bystander
I’ve never bothered looking at a single utube review of hifi kit -indeed. I don’t see the point at all: totally pointless as the sound is heavily constrained before even whatever one uses to listen.
Posted on: 01 December 2018 by Mercky
The RA10 is a nice little punchy amp for a few hundred quid
Posted on: 01 December 2018 by Robiwan
Iconoclast posted:
Robiwan posted:
the nait 5si
Robiwan posted:
Iconoclast posted:
Robiwan posted:
the nait 5si
When my old Harman Kardon integrated died on me many, many years ago I picked up a Rotel RA-1062. Hated it and sold it immediately. I then owned a Cambridge audio 650 (too bright), then a Nait 5i (lots of fun but too thin) and finally an XS 2 (70W). At first I found it sounded dull and lifeless compared to the 5i but after a while I realized that it was much easier to live with and have yet to find a replacement. Mainly for fear of later regretting it or for lack of budget for a sure thing like the SN 2.
Posted on: 02 December 2018 by RaghuV
I have meaning to move my kit to an larger open landing and making it a proper man cave with a soundproof wall. Figured I needed more power. Was also contemplating a pair of Magnepan 0.7s that I heard at a dealer nearby.  Not as a replacement, but as a complementing pair to the Harbeth.
Read that the Magnepans would need more power and current. The Rotel has a provision to manage two speaker sets.
Figured I would get better performance and enough oomph to handle more demanding speakers.  And for 900 dollars, the used Rotel sounded like it would do the trick from reviews, including one from Steve Gutenberg.
Discovered it didn’t.
Stephen Tate posted:
Daniel H. posted:
What would constitute and exceptional source?
Posted on: 02 December 2018 by Innocent Bystander
RaghuV posted:
Whilst the continuous power capability of the RA1570 is rated at twice that of the Nait (that’s 3dB), it may be that its peak power - needed for that grip on transients - is no more, maybe less: the Nait claims 300VA, which is five times the rated continuous power, an unusually high margin in the amplifier world, that of  the 1570 unknown but very possibly no greater, maybe even less. With music having at least a moderate dynamic range, the Rotel might not offer any more available power in practice before amplifier clipping.
As for two speaker sets, remember that if two are connected it is a bigger load on the amp.
Of course, there is then the question of the sound of the amp, and, if not identical, which you prefer. What had you heard before you first got the Nait?
Posted on: 03 December 2018 by Massimo Bertola
RaghuV posted:
I think this says all.
I have owned Nait, Nait5, 5i (not italic), 5x, Nait XS, Nait XS2* and a couple of Supernait. I still remember when I demoed a pair of Raidho C.1s with a Nait5si, when no amp seemed able to extract enough sound from them and being speechless; and the famous quote by David Wilson (of Wilson Audio) that a rumor wants having replied to someone complaining about the difficulty of driving his speakers, 'Try a pair of Sophia with a Nait 5si'.
Moral: stick to your 5si and let the Rotel to those who believe that the plainest, the ugliest, the less assuming is by default also the best sounding. It won't feel alone on a store's shelf, in the company of generations of NADs...
Enjoy!
Max
* My current amp, and the one which has finally reconciled me with home music replay.
Posted on: 03 December 2018 by Bob the Builder
When I bought a UQ2 a couple of years back I auditioned a Rotel with built in Dac might be your one and an Arcam fmj something and also the upright Nad 7 something D anyway both the Rotel and the Arcam where disappointing big powerful lifeless beasts, the Nad was better but then the dealer pulled out this beautiful diminutive little black box and wow I mean it really, really was night and day,  double the price for half the amp that was ten times better.
Posted on: 04 December 2018 by RaghuV
RaghuV posted:
Befor the Naim, I used a Yamaha RX-2700 receiver with B&W 704s, with B&W gear for a 5.1 setup. Didn’t really enjoy music as much through this setup in 2.1.
Moved to Naim 5si with KEF LS50 for dedicated music in India.
I added a pair of Harbeth 30.1s when I moved to the US.
Been listening to the Mac Mini, Audirvana Plus, Musical Fidelity V-90 DAC with the Naim and the Harbeth for circa a year.
