Blown away
Posted by: DuncPC on 06 December 2018
Well tonight I have removed my 82 and twin hicaps from my Olive 250 active system and popped in a lovely 52 and carnt believe the difference.
It has opened up the sound completely, better bass, better detail, just better everywhere, so much so I can't believe the massive difference it has made, I now see what all the fuss is about with the 52 and even cold it's unbelievable.
If anyone ( like I was ) feels that a 52 can't be that much better than say a 82 even running a suppercap, then I am sorry to tell you that you are very wrong and like I said I would have not believe it myself until about an hour ago and I switched it over, even plugged my 82 and tried it with the suppercap just in case that was making the huge difference, but it wasn't, and it's not like my 82 is in need off a service ECT, as it's pots 8 upgrade and serviced not that long ago.
Anyway just very happy with my new sounding system
Posted on: 06 December 2018 by DuncPC
Title should be blown away, can it be changed please as it's looks a bit strange and I blame thick fingers
Cheers for sorting it
Posted on: 06 December 2018 by FangfossFlyer
Enjoy!
Posted on: 06 December 2018 by Mike Sullivan
That’s the spirit!
Posted on: 07 December 2018 by Obsydian
Awesome.
I recall long while back in an old system, i went 92, 72, 102, 82 and then 52 - the 72 and 52 where special.
Posted on: 07 December 2018 by Bruce Woodhouse
Good to hear
I sold my 52 a few months ago for a 252/Scap DR and it has taken me a while to be completely convinced of the benefits. There was something about the 52 that my new pair does not quite have, although in other areas it is better.
If you can stretch to a Scap (not necessarily DR) at some point your pleasure will be greater. Also check with Naim when it was serviced and if it is the 'final' spec (called Pots 8 or something). This is worthwhile doing as they did improve them over the lifetime of the product.
Bruce
Posted on: 07 December 2018 by hungryhalibut
The OP must have a Supercap, as the 52 won’t work without one.
Indeed HH, well spotted! (or a 52PS of course)
Bruce
Posted on: 07 December 2018 by Steve2
I echo Duncpc's thoughts.  I moved from a 72 to a 52 with Supercap and could not get over the transformation it had on my music.  No desire to change anything in my system but if I won the Lottery.............
Posted on: 07 December 2018 by DuncPC
My 52 is one off the latter ones that came with pots 8, rather than fitted latter.
Just need to get my new rack, with ball and cup, 10mm glass ECT and that should make it all sou d even better as at the moment I have a metal and glass rack that was made by a local guy that listern inn used, as he main racks for naim gear, but we are talking 20 years or more, so it time for an upgrade
Posted on: 07 December 2018 by Bob the Builder
This will be my last upgrade next year or yer after I have s SC ready.
Posted on: 07 December 2018 by MDS
Bob the Builder posted:
Oooh. Now I wonder how many of us on here have used those words?
Posted on: 07 December 2018 by Premmyboy
I run 52/supercap with Nap 300 non dr. Fabulous not intending any further amplification upgrades.
Posted on: 07 December 2018 by Japtimscarlet
I went from olive s/cap to s/cap Dr and found a nice improvement...and the olive was serviced and in good fettle ...
