Sudden Radio Poverty
Posted by: Mike1951 on 08 December 2018
So, having reset the streamer and solved my previous problem (see below), I’m trying to reload my favourite stations and I’m discovering that most of the planets’ online radio seems to have vanished.
Going to ‘location’ and keying in Countries/States now delivers ‘Genres’ which break down into a miserable one or two stations per area! Are you actually trying to tell me there’s only three rock stations in the whole of New York? Or two ‘alternative’ stations in California?
Seriously. What the actual ....?
Edit: Oh wait... ‘All’ stations... oops. ????????
As you were.
Posted on: 08 December 2018 by ChrisSU
It would certainly be a lot easier if you could do a ‘global’ search with the app, for UPnP as well as iRadio. For example, to find Radio Paradise, you would have to know that it was North American. Then that it was based in the US. Still not enough, you need to find out that it’s in California. Ah, hang on a minute, that only lists the 192kbps stream, where do I even start hunting for the 320 stream? Oh, x*# it, i’ll just listen to something else then!!
