Chord Qutest ?
Posted by: james n on 17 December 2018
Anyone using one. It had a good review in HFN but they mentioned the supplied Wall Wart wasn't too good (or at least the 2 samples they had - bad batch ?). Is this the case for those that own one ?
James
Posted on: 17 December 2018 by SongStream
I've been running a Qutest with the stock power supply for around 10 months.  No problems, though I will admit, coming from a world where hefty looking power supplies with massive capacitors and transformers are a big thing, it does look a bit pathetic.  The Qutest does sound very very good though, so as long as it actually works, the dodgy looking power supply is clearly not a problem.
Posted on: 17 December 2018 by cat345
No problems with the power supply and I don't have to worry about the batteries anymore!
Posted on: 18 December 2018 by james n
Cheers both - good to know
