Ndx systemautomation
Posted by: Anders in småland on 17 December 2018
Hi everybody!
I have just got my hands on a NDX and trying to get systemautomation to work. It is connected to a ndac and that part works, but the preamp not. It`s a 282. A 3.5 jack to rca left is connected and enabled in the ndx menu. Volumeknob not moving, pre input not switching. ALso tried the right rca to.
// Anders
Posted on: 17 December 2018 by Bart
You also need to enable it in the Naim App.
Posted on: 17 December 2018 by Anders in småland
Bart posted:
Hi. Thanks!
If you mean in the app, under other settings, volume bar then it’s done.
Posted on: 17 December 2018 by ChrisSU
Have you got two system automation cables, to DAC and preamp, as per instructions in the SA manual?
https://www.naimaudio.com/site...ystem_automation.pdf
ChrisSU posted:
Yes. Two cables connected from NDX.
Posted on: 19 December 2018 by Anders in småland
Now have done a factoryreset in systemautomation and later the hole NDX.
The setup was then made in accordance to the sys auto guide page 3, but still no answer when i press volumebutton in the naim app.
Sad but the sky won’t fall down.
