Nova Subwoofer
Posted by: AirKing on 29 December 2018
Hi
Can anyone help please, looking to purchase a Pmc Sub to go with my Twenty Five.22, would the Nova out go straight into the subwoofer?
Anyone also tried this?
many Thanks.
Posted on: 29 December 2018 by Pev
I use a Velodyne sub with my Nova - standard RCA lead from Nova pre/sub out to Velodyne low level input. I don't know your sub but I would assume it would connect in the same way. You can connect via siamesed speaker leads for a high level connection.
In my opinion the key thing to get a sub to work in a given system is the integration and that is much easier if you have some kind of frequency analysis software and ideally a microphone at the listening position. There are a lot of threads on this topic if you search this forum.
Posted on: 29 December 2018 by AirKing
Many thanks Pev, I will see what calibration software which might help required.
cheers
Posted on: 29 December 2018 by Bart
AirKing posted:
cheers
REW is a free download; you just need to buy a specifically calibrated microphone.  The USB mic is about $99.00 here in the States.
Posted on: 30 December 2018 by AirKing
Thanks Bart will check it out.
