Running a Nac72/HiCapDR/Nap250DR.
Is it safe/advisable to connect a Subwoofer to one of the three 4-pin outputs of the HiCap? The HiCap has 3 outputs - are they all the same? ( I found a 4 pin to RCA cable that I'm using).
I've got it hooked up and it seems to work - not done any phase integration yet...
Posted on: 03 January 2019 by Richard Dane
You can do that - the Hicap just provides a stereo pre-out on each DIN4. However, you need to be careful as the Hicap was never designed to drive a long interconnect. Naim themselves used to fit a 100R resistor to the DIN4 on their own subwoofer lead to ensure stability.
Posted on: 03 January 2019 by Bart
I think that you can buy a din to RCA lead with a resister (to the Naim spec) already fitted -- I forget where I saw it but will look!
Edit: It's from Flashback Sales in the UK. They ship to the US
