Suitable MC cartridge for SME 3009/S2 improved, detachable head shell
Posted by: Dasher on 07 January 2019
I have had since 1976 a Michell Transcriptors Electronic TT fitted with a SME 3009/S2 improved, detachable head shell. It hasn't been used for many moons and is due to return to Michell for a full service sometime soon. In preparation for its future use I want to use this with my 62 / 90 / Hi Cap + LS3/5a's. I believe the phono board in the 62 to be a 323K, as originally this system was hooked up to an LP12 / Ittok / Asaka. (The LP12 is in use in my main system elsewhere).
As I understand it, I should be looking for a high compliance low output moving coil cartridge. Does such a cartridge(s) exist ? Or, should I have to compromise and look for a MM and then change the phono board in the 62, which may be difficult in itself in finding the appropriate item. Sonically I wish to stay with MC if at all possible, but I would like to avoid adding to the box count by adding a phono stage to accomplish the above.
What options do I have ? Suggestions gratefully received.
