sbl tweeter enclosure
Posted by: ern on 11 January 2019
HAS ANY ONE REMOVED AND REPLACED BANANA SOCKETS FROM TWEETER ENCLOSURE .
IF SO WHAT IS THE PROCEDURE TO REMOVE AND REPLACE AFTER REMOVING TWEETER FROM THE ENCLOSUE
Posted on: 11 January 2019 by Christopher_M
Why do you ask? Is there a problem?
Posted on: 11 January 2019 by Richard Dane
Ern, it's probably a question best asked directly to Naim or a Naim dealer who has done driver changes and updates in the past. DIY discussion such as this rather falls outside of forum AUP.
Posted on: 11 January 2019 by garyi
I can tell you this for free, getting the tweeter out without ruining them or the box is very very difficult
