AV Bypass NAC 282
Posted by: scubafink on 11 January 2019
Hi all,
a purely technical question.
I have connected the front speakers of my Marantz av8802a preamp to the av input on my 282. I then use the 282 remote and hold the prog button and the mute/CD buttons illuminate on the 282 and the volume control knob flashes. Does this mean all is setup now?
Posted on: 12 January 2019 by Richard Dane
Once in Program mode pressing the source Mute button twice toggles Unity gain on and off - on is indicated by source mute illuminated.  Then exit program mode.
