Cd555 dual interconnect
Posted by: Emre on 11 January 2019
Hello
A small question to all friends in the forum
can I connect both din to pre and rca to headphone amp and use both ?
Posted on: 11 January 2019 by Richard Dane
You can, but for best performance make sure you switch between them rather than have both enabled at the same time, which is a performance compromise. Only thing I don’t know is if there’s any further compromise having something connected to the other output even when switched off..
would it not be safer to just take signal from the tape out of the preamp?
Posted on: 11 January 2019 by Emre
Many tnx
I was doing that with 272 but can I do it with rca nac552? Also looks like I will connect 2 headphone amp.... one electrostatic one solid state
