Dual Hicap 82
Posted by: Guinnless on 11 January 2019
Does this setup have a compromised ground with signal only running through one Hicap?
Posted on: 11 January 2019 by Richard Dane
Essentially, yes, the signal earthing arrangement is slightly compromised compared to a single PSU such as a Hicap or a dual connected Supercap, mainly because only one Hicap has the signal running through.
Posted on: 11 January 2019 by Guinnless
Thanks Richard. It helps with some decision making. I have searched for pros and cons of dual Hicaps and unlike with most Naim upgrades there seems to be "big difference" , closely followed by "not much difference". I then wondered if it could be down to the earthing.
Posted on: 12 January 2019 by Guinnless
I'm assuming the earth arrangement when using a Supercap doesn't have the same compromise? ????
Posted on: 12 January 2019 by james n
You assume correctly
