Running in a SNAIC
Posted by: JimDog on 14 January 2019
If one was running in a new SNAIC, should you leave the preamp playing continuously to speed up the process - and does it matter if the amp is muted or the volume turned to zero?
How long will that normally take?
Posted on: 14 January 2019 by james n
I'd just plug it in and not worry about it.
