NetGear ReadyNAS Duo resync
Posted by: ken c on 04 September 2011
after a power cut while i was away, on switch on, the NAS (correctly) went into resync mode, but its been doing this now since 1500hrs yesterday! i have a 2x2TB in RAID config. is this normal? I guess the fact that i managed to play ripped music from it would suggest all is OK, but i am just a bit nervous. annoying that a UPS for it had been delivered while i was away and therefore not yet installed. damn!
any thoughts, advice, gratefully received
enjoy
ken
2TB of data is quite a lot to deal with and the whole disc will be checked whether there is data there or not.
Should be all right in the end...
Tony
Hi Ken - i've had this on my NV+. Took an age to resync but all was ok. Like yours, it had gone off during a power cut and so after that episode i bought a UPS.
James
As long as there is progress, albeit slow, on the status bar I would have thought you are ok.
Slightly curious though, when mine is resyncing, the NAS i seem to remember is not mountable, and you say you've copied files from it whilst resyncing?
Simon
Simon
thanks simon. no, i dont believe i have "journaling" enabled -- i dont know what this is and dont recall reading about it?
i havent actually 'copied files' from it while syncing as such. i have merely played some music from it via the US, and this played OK.
rgds
Ken
James
thanks for the reassurance james.
actually thinking about it now, i wonder whether a UPS really helps. if power goes off while i am away, the UPS will keep maintain backup power for an hour or so, then after that, no protection! unless there is a way to instruct the UPS to automatically shut down the NAS gracefully when power goes off -- that would be neat. or am i simply missing the point.
enjoy
ken
Tony
thanks Tony, will do...
enjoy
ken
wow! what a coincidence -- the resync just finished! message from my NAS
"RAID sync finished on volume C. The volume is now fully redundant.
[Mon Sep 5 08:02:29 WEST 2011]"
Phew!
Thanks guys...
But would appreciate comments on what happens when power off while one is away for long. i guess the thing to do is to shut down the NAS?
enjoy
ken
Ken - the NAS is connected to the UPS via a serial cable and then instructs the NAS when its on battery power. When the battery drops below a certain level the NAS is instructed to shut down. It then stays off until i power it up again.
James
another question: i also received this message from my NAS when i powered it up after the power failure:
Improper shutdown detected.
To ensure data integrity, a filesystem check should be performed as soon as possible. In Frontview:
1. Click on the System button.
2. Go to the Shutdown tab.
3. Enable the volume scan on next boot checkbox.
4. Reboot the device.
Now that the resync has successfully completed, do i need to bother with this or did the resync take care of this as well?
many thanks
enjoy
ken
James
thanks James, my UPS is APL RS800. i dont see the any possibility to connect a serial cable (RS232) to the NAS as there are no compatible connection points on either side. or please explain further?
enjoy
ken
james, many thanks. the behavior you describe is exactly what i am after -- so will check, with interest
enjoy
ken
This is the one i use
APC Back-UPS 350, 230V
thanks james, looks very similar to mine, which is an 800, probably overkill. i guess i haven't read the provided manually thoroughly enough (consistent with 'when all else fails, read the manual') -- will do so soon, work allowing.
enjoy
ken
