Bit the bullet and decided to try the NDX . My dealer has kindly loaned me one at short notice to use over the next couple of days and i picked it up tonight after work.
I expected to be spending a good hour or so setting up, but it was up and playing music within 5 minutes of coming out of the box. So far so good...
James
Posted on: 05 September 2011 by Fred11
Hi James, are you able to say anything yet, about how it compares to your Akutate DS? I have been thinking of buying either Akurate mk1 or Ndx but have not been able to read about any direct comparison between the two. Good luck with your demo!
Fred
Posted on: 05 September 2011 by james n
Hi Fred. First impressions are that it's very good. The same can't be said of the n-stream app which is very disappointing compared to the Chorus and Kinsky apps I'm used to. Shame :-(
James
