Problem with FLAC 24 bit 96 khz
Posted by: marinus on 09 September 2011
Hello,
Approx febr this year i asked at the NAIM help desk what the max. format was which can be played on my Uniti.
I got replied that FLAC 24 bit / 96 Khz the max is (by Stephen Hopkins)
On the Channel site i bought music download in this format ,but  my Unit gave error - Can't Play - Unsupportded file format.
My uniti has the latest firmware installed at a official dealer.
Can anybody give assistance.
Thnk
Marinus
Posted on: 09 September 2011 by Peter_RN
Hi Marinus
Well the Uniti can certainly play the files.
I don’t know the Channel site but you could check to ensure that any artwork is of a reasonable size (say 200k max); it might be worth re-booting the Unity.
Have you tried to play the files on another player to ensure the are OK?
Peter
Posted on: 10 September 2011 by marinus
Peter,
Thanks for your reply.
What do you mean by the artwork should be reasonable size.
( sorry - i am not on that level a ICT specialist)
I just played the files by Foobaar 2000 to UpNp and it worked.
Even other testfiles worked surprisingly
By the way in the display is showed 44,1 Khz WAV file ( which isn't ) in the properties of Foobar2000 is showed sample rate 96 Khz and bitrate 2479 kps  FLAC.
Hope someone can give advice.
Posted on: 10 September 2011 by Peter_RN
Marinus……Foobar is an excellent music player and has become my favourite way of playing to the Qute. AlbumArt size will not affect playback by Foobar, but may if you use the Qute’s remote to select and play music directly from your NAS. You may need a tag editor if the artwork is embedded in each file to establish/change its file size. If you have a ripping program already you may well have a tag editor. I tend to limit file size to 200K max, many of mine are much smaller than this and work fine.
As for Foobar, you need to setup your preferences under Tools/Server/Streaming Profiles. Here you tell Foobar’s UPnP server how to handle your files for streaming to the Qute. At the top of the page you set the ‘Renderer Capabilities’…..44100…to….96000…….Max bit depth 24
By setting these options Foobar will play your files up to 24/96 as they are, but should you have or get any 24/192kHz files it will automatically downsample them to 24/96 and allow the Qute to play them without any further action from you.
Towards the bottom of the page ‘Decoding to PMC’.  If you set this option to ‘always’….and ….’WAV’, Foobar with transcode your files to WAV before sending them to the Qute; from your description of what the Qute screen reads it sounds as though this is already selected. I would suggest you leave it set that way as Naim products are optimised for WAV.
Hope that helps
Peter
Posted on: 11 September 2011 by marinus
Dear Peter,
Thanks for your explanation.
A simple start up gave the solution - On my NAS (QNAP) is Twonky media installed which now plays the 96khz files excellent.
I just tried via Foobar + PC because via the NAS it didn't work.
Marinus
