New to home theatre ish
Posted by: fathings cat on 17 September 2011
Hi I have a samsung DVD/blue ray 5.1 system and to be fair it's pretty poor......
If I wanted something of a better quality what should I look for - budget is pretty limited so plan to take a chance on eBay but what would you guys recommend.
Not sure if relevant but tv is a samsung 42" plasma approx 3 years old
I have a sky box but sadly my main system 252/205.2/ndac/serv is not in close proximity to my tv.
Any recommendations welcome
Gary
Posted on: 17 September 2011 by NickSeattle
Keeping AV and hifi separate is not all bad!  I'd get a sound bar + sub for AV and get on with life.  The only reason I keep my 5.1 system is it is already wired in-wall and the speakers are fairly nice.  Top of the line Yamaha or better sound bars are amazing-sounding, especially considering how affordable they are compared to true 5/7/9.1, and 2.0 Naim.  That is what I'd do if I were starting anew; and focus surplus energy and £ on hifi.
Nick
Posted on: 17 September 2011 by fathings cat
Thanks Nick, seems like good advice.
Any recommendations on spefic models?
Gary
Posted on: 17 September 2011 by tonym
Sound bars have an interesting effect, but they're not really proper surround sound. They also tend to have one 'hot spot' & can sound distinctly weird if you're sitting off-axis.
We've got a Yamaha soundbar in the kitchen & it improves the sound from the Samsung TV considerably (not difficult)
You've a very good stereo & TBH unless you go for a decent setup you're going to be disappointed. What's your budget?
Tonym is correct, of course.  And, depending how picky you are, you might not like any sound bar as well as your current 5.1 system, which you call poor.  (You clearly appreciate very good sound!).
Not being in the market for similar goods myself, I cannot offer any specific ideas.  Good luck with your quest.
Nick
Posted on: 17 September 2011 by trickydickie
If budget is really tight then a used Yamaha DSP-800 may suit.  This is a 5.1 processor that provides amplification to centre and rears with a line level sub output.  The fronts are provided by your existing amp and speakers via the unity gain input on your Naim so Just add centre and rear speakers to suit.
I've found the Monitor Audio Radius work well, compact and smooth and easy to install if space is tight, but there is plenty of choice in used speakers.
I've just changed over from the Yamaha to a Naim N-VI which slotted in perfectly and saves me a shelf as it had the built in tuner as well.  Clearly a nice asthetic match for the other components and very compact.  It was buggy at first but a quick email to Naim and prompt response with a firmware update resolved all of these issues.  The Naim N-VI sells for relatively little money if you keep your eye out.
This is all in context of a much more modest system (202/200/NAPSC, Spendor A5)
Richard
Posted on: 18 September 2011 by fathings cat
Thanks guys, budget is not set as I was going to have a good hunt on eBay - definitely not buying new.
To be honest home theatre is a little bit of an experiment hence my desire to experiment with second hand components - I had hoped to get something "better" than something samsung chucks out.
Sound bar looks a cheap potential option -a few on eBay that could be with a punt.
Thanks for your thoughts so far and would welcome anyone else that has thoughts.
Gary
Posted on: 18 September 2011 by tonym
OK Gary, I'd go along with Richard's suggestion but it doesn't appear feasible for you to incorporate your present stereo system into a surround setup.
Best plan, if you decide not to go for a Soundbar (and unless you are constrained by placement of the five speakers plus subwoofer needed for a true surround sound system I really wouldn't recommend one) is to base a system round a processor/amp from the likes of Denon, Yamaha or Onkyo, ideally that can decode HD audio. This will have all the amplification on board save for the subwoofer which will generally be active & have its own amp on board. There are bound to be plenty for sale S/H, have a look on AV Forums as well as e-Bay. One with an HDMI input/output would be good.
Then you need a set of speakers, but with a decent amp fronting them, as long as they match and are from a reasonably reputable manufacturer, you'll get a pretty good result. Matching the subwoofer's not quite so important but don't be talked out of a centre channel speaker!
Good luck.
Posted on: 22 September 2011 by fathings cat
Thanks for your help guys - appreciated.
I think I need a bit of time to reflect next steps
Gary
