How to add pics to the post?
Posted by: AMA on 20 September 2011
Did it before but it seems the rules have been changed...
Posted on: 20 September 2011 by Gale 401
Posted on: 20 September 2011 by BigH47
AMA, the system is the same as in the FAQ.
I will add that sometimes it acepts the picture you can see after it has been inserted, but does not show on the forum.
It often seems to be after using the picture in say "What new CD?" and then try and post in "What are you listening to?"
Copying an already posted picture from another poster does not seem to work now.
Howard,
Music room pics work ok most of the time.
Last week you said you couldnt see one of mine,Thats because i copied it from discorgs.
Some of those show but not on the forum.
Stu
