HDX radio failure!!
Posted by: kingsfan on 29 September 2011
Hello Naim!
I tried to install the internet radio yesterday on my (1.5a) HDX. I downloaded the file 1.6b from the homepage on a CD-R and everything went well until the machine should re-start itself. Now I have a massage on the display "Firmware upgrade failed, please contact your dealer..."
What am I suposed to do now? I live in Sweden and I don“t know if my dealer can help me.
I have not powered it down yet. Will I have to send it to Salisbury?
Best regards / Hans Christensen
Posted on: 29 September 2011 by osprey
Hans, I think that when you face any problems it would be best to contact your dealer first. They should know what the proper procedure is if anything need to be sent back to Naim for service or repair. Secondly, you could mail to Naim support. They usually give their answer/advices quite soon (within a day or two).
Posted on: 30 September 2011 by Klout10
Any news/progress yet??
Michel
Posted on: 30 September 2011 by seun
I had a similar problem to you Hans, I rebooted without the internet connection,
Posted on: 30 September 2011 by Phil Harris
In that case you have nothing to lose by doing a reboot which will usually clear the issue ... it shouldn't matter whether the network is connected or not.
Phil
Posted on: 30 September 2011 by kingsfan
Thanks all, The radio is up and running. The reboot fixed it
/Hans
Glad to hear that everything is OK, you'll love the new iRadio functionaliy!
Michel
