Flac player for iPad/iPhone
Posted by: Ellsworth on 02 October 2011
Apologies in advance if this is a re-post. I couldnt find it in the search feature. I've been using the flac player app on my iPhone and it works very well. Im using the Dr. Dre in ear-phones with it and I'm very impressed with the quality. No more converting files. Happy days.
Also for those of you who are still struggling with cover art showing on the n-stream app I found a very odd solution. I tried all the folder tagging, new (borrowed) router, Asset upnp stuff and finally gave up. I could always stream hi- def flac if i used the Naim remote but not when using the n-stream app. I got the plugplayer app and all cover art appeared in the app immediately and the streaming worked. The bizarre thing was once the plug player app worked, I tried the n- stream again and it worked perfectly! This followed a year of messing about. I understand this is bonkers but it worked. Hopefully this info may help others work this frustrating issue out too.
