Naim DAC - Connectivity?
Posted by: Lewy on 04 October 2011
Hi guys
How would one connect left and right phono to the Naim DAC?
I wish to connect my Virgin box to the NDAC but not sure what cable I would require
Can you get, either:-
1. Left/Right channel RCA phono to Coax SPDIF?
or
2. Left/Right channel RCA phono to Digital SPDIF?
Anyone done this and point me in the right direction?
Lewy
Posted on: 04 October 2011 by Frank Abela
If your Virgin box has a digital output, you would use that. Digital outputs are usually optical through a Toslink connection or coaxial via either an RCA (phono) connection or BNC connection. Only one cable is required and you should set your Virgin box to send only 2-channel PCM, not bitstream so the DAC can decode it.
If all you have on the back of your Virgin box is Right/Left sockets, those are analogue and they should not be connected to the DAC. They may be connected to your amplifier in the same way as you would connect a CD player or radio tuner.
Frank.
All opinions are my own and do not reflect the opinion of any organisations I work for, except where this is stated explicitly.
Posted on: 04 October 2011 by james n
Which Virgin box have you got Lewy ?
James
