Artist Info on Compilation Albums
Posted by: heihei on 06 October 2011
Anyone any idea how to get this info into the system for discs ripped on a Unitiserve??
Posted on: 06 October 2011 by Stoik
I can't help you directly with your specific question. But I had a miserable experience with iTunes at trying to rip CDs with lots of "featuring" artist. If there's 20 tunes of that type on the CD, you'll obtain 20 "albums" in iTunes with only one tune in each of them.
A workaround I found is to use another ripping software to do the job... after cleaning up the mess in iTunes, of course. As it's almost impossible to predict when it's going to happen. I use EAC to rip in FLAC when I have to (I'm using iTunes only to rip in Apple Lossless).
Bye.
Posted on: 06 October 2011 by Manu
I-tune is not the best ripping software, whatever format...
Posted on: 07 October 2011 by pcstockton
Artist vs Album Artist.  Any player/ripper worth its 0s and 1s should handle both tags.
Album Artist = "Various", "Multiple", "Soundtrack", "Varese" etc...
Artist = "John Zorn", "Mike Patton", "LSO", "Uri Caine" etc...
Posted on: 07 October 2011 by Guido Fawkes
All you have to do on iTunes is click the compilation box and it works perfectly - no idea why it doesn't work on US though, it should do as Patrick says. In iTunes if you leave the the Album Artist field blank it will default to Various and file it at the end of Library, whereas if you insert "Various" it will file under V.  The Vortexbox does this too.
Surely the UnitiServe must have an app or web interface that lets you edit the tags and insert your preferred cover art? If it doesn't it needs it. Does it support the compilation tag?
Posted on: 07 October 2011 by Bart
The uServe certainly does have an app that lets you edit tags and album art -- it's the "desktop client" that presently is Windows-only.
A compilation can use the Album tag to name it, and "Various Artists" as Artist.  I am at work right now and so I can't connect to see how "Artist" is handled on an individual track basis on such compilations but I'm sure others will chime in.
Posted on: 07 October 2011 by Stoik
Of course, but it had to get out. I feel better now.
dBPoweramp FTW!
Bye.
Posted on: 08 October 2011 by Simon-in-Suffolk
I do use dBpoweramp, and if the compilation flag is set on a rip artist info is described for each album track, and the overall artist goes to Various. There is also scope for Album Artist in addition for compilations, performances  or  mixes by a particular arist of note.
Displays nicely on nStream when using asset. Very useful for large compilation albums, and allows easier track searching.
FWIW it appears the logic in eLyric is broken. For non compilations the artist lookup works, however for compilations, eLyric fails to use the track artist for lookup and tries to look up 'Various Artists' holder value for overall artist, which is useless.
Simon
Posted on: 12 February 2012 by Terrysmi
I have an NDX which streams CD's ripped from a Uniti Serve and on compilations artist is simply shown as "Various Artists" . An earlier post suggests that you can change this via the desktop client but i cant see how to. Can anyone help ?
Posted on: 13 February 2012 by pcstockton
Terry,
Set "Album Artist" to either "Various' or "Stockhausen" etc.
Then set "Artist" to the actual artist playing.
I cant say how things will sort for you though.
In J River this would put the album in "Multiple Artists" in Artist View.
-Patrick
Posted on: 13 February 2012 by rhr
The HDX (and I assume the UnitiServe) rip compilation albums with the album artist set to Various as it is a compilation. The Server then adds the Song's artist as it's performer, you can then search for songs via the  HDX's interface using the Browse Music and then the Performer.The information is then stored in an xml file within the folder that contains the Album.
The servers don't really have the MP3/flac tag concept of Artist and Album Artist. The HDX seems to ignore the Album Artist tag in any MP3s and FLAC files that it may be pointing at on a Network Share. This makes looking at previously ripped compilation albums quite difficult.
This does mean that when serving the files as a uPnP server, one can't see the all the song's by a particular artist under the artists menu. You have to check under the performer part of the tree.
I do find this to be one of the downsides of using the HDX as a uPnP server.
Hope this helps,
Rich
Posted on: 13 February 2012 by winkyincanada
Bye.
There's no need for a work-around. Just select all the songs once they're ripped and go to "get info". Edit the "Album Artist" field to whatever you like (usually the main artist, but if it is a true compilation album, you'll have to choose something that makes sense e.g. "Tarantino" or "Various Artists" for the Pulp Fiction soundtrack). I've just tested this again it works perfectly for me.
Bizarre.  Both "Artist" and "Album Artist" are widely used and very standard tags.  I don't think I have ever thought about using "Performer" because of that.  I would use that for Classical possibly, to list the Orchestra or Ensemble, but I dont view that tag (and wouldn't want to) in any of my views.  Also, I always tag my "Album" name with any relevant info about performer, conductor, record label etc...
A media player should use "Artist" and "Album Artist" interchangeably until there is a conflict.  Then it should list the album as "Various Artists" or "Multiple Artists".  Most players look for one or the other and if not there defaults to one with existing tags
John Zorn - Voices in the Wilderness is a various artist album of Tzadik artists playing compositions by John Zorn.  Although it is technically "various", I want the album to be found under "John Zorn", not "Multiple Artists".
If you have a various artist/comp album and want it to show up under a particular artist rather than "Various", as with the above, I would set BOTH "Artist" and "Album Artist" to John Zorn then write the actual artist playing into the "Track Name" tag.
Posted on: 14 February 2012 by Nick B
@heihei & Terrysmi
AFAIK having ripped ~500 compilation albums using a Unitiserve over a period of about a year, and having struggled with this issue for about the same amount of time, to the best of my limited knowledge there is currently no ability within the desktop client or anywhere else to specify 'Artist' at song level, only at album level.
I'm not at home at the moment so can't verify, but what rhr states re: the artist of each song from a compilation being filed under 'Performer' rings a bell - although one could consider this system less than perfect as you have to do 2 searches to find all songs by an artist: once by Artist to find all the albums by that artist, and another by Performer to find all the compilation albums containing song(s) by that artist (who will be listed as the Performer of the song) - then select the compilation album from the returned results of the Performer search to see the song(s) with that Performer contained within the compilation album. Not great.
In the short term I resorted to renaming every track on every compilation album I've ripped from just the song title to "artist - song title" and I use the track search facility to search for the artist instead of searching by Performer. Again, not optimal but it's the best solution I've found for my needs.
I recall a post on here late last year that full(er) metadata editing may be enabled in a future update, maybe this will include a method to tag compilation albums and the artists of the songs within so that one only has to run a single search against artist to find all albums by that artist as well as compilation albums containing songs by the artist.
Hope this helps you in some way
Posted on: 14 February 2012 by spartacus
Bye.
+1 on that Winkyincanada. That is exactly how it works on for me. If I then search for a track by name or an artist on the Apple remote running on an iPad I get all the results but they are then grouped by Artist and/or tracks and or albums that include the search term. If I choose an artist it drills down even further or I can just play the album or song straight from the search results.
Doesn't seem messy to me.
Posted on: 14 February 2012 by m0omo0
@Nick B
I'm interested in this as I may be contemplating a Naim server in the future. What seems to be alluded to in the 'Naim Extended Music Database' white paper from 2008 is that Naim came to their own solution that differs somewhat from what is commonly used elsewhere.
If I read correctly, 'Performer' is a notion that you can find at the album and/or at the track level. 'Artist' seems to be a more "vague" notion at the album level. It is a bit as if 'Artist' would relate to the "marketing" side of the album (who is "selling", if I may say so), and 'Performer' would relate to whom is actually "working". And I suppose that you can have more than one 'Perfomer' per album or track.
If I'm taking Patrick's example (coz' I like JZ very much), the 'Artist' could be John Zorn (and also the composer I guess), the 'Performer' at the album level could be 'Various Artists' and the 'Performer' at the track level could be each individual band paying tribute to Zorn's music.
If the white paper is correct, if you browse or search John Zorn, you should see this tribute album.
I do something similar in iTunes (for iPhone syncing): I use ARTIST and ALBUM ARTIST sometimes differently. For instance, I can group all Charles Lloyd formations under the ARTIST Charles Lloyd, but the ALBUM ARTIST can be either Charles Lloyd, or Charles Lloyd Quartet, etc.
The Naim way rings a bell indeed, as I don't like to have more than one information in each tag if possible, but I don't know if I got it right ?
In any case, the problem of not reading correctly common tags in files ripped elsewhere sounds like a bug to me.
Maurice
Posted on: 14 February 2012 by winkyincanada
Yes, the search is flawless, on the iPad or directly on the host PC. Never misses. I don't know how I could want more than iTunes offers in regard to library management. I have about 1000 CDs on my Mini and it is still instantaneous, either on iPad orby screen sharing with the Mini.
Originally Posted by m0omo0:
......'Performer' is a notion that you can find at the album and/or at the track level. 'Artist' seems to be a more "vague" notion at the album level. It is a bit as if 'Artist' would relate to the "marketing" side of the album (who is "selling", if I may say so), and 'Performer' would relate to whom is actually "working". And I suppose that you can have more than one 'Performer' per album or track.
Maurice
I think this is a stretch.... Artist? Performer? Who cares? Adherence to a common standard is much more important than esoteric definitions.
I rarely intervene with iTunes' tagging, It does a great job. It is just those compilations that give me a little grief from time to time.
Posted on: 15 February 2012 by pcstockton
Some like more info, some less.  To each their own.
I like knowing it is Boulez at the helm conducting Stravinsky.  I also like knowing which release I am listening to in the case that I have more than one version of a favorite.
Stravinsky - Le Sacre du Printemps {Boulez}
or
Steely Dan - Aja {MCA - Hoffman}
Steely Dan - Aja {MFSL UDCD 515}
I realize this doesn't work for you because iTunes wont find art for those albums with brackets.
-Patrick
Posted on: 15 February 2012 by winkyincanada
or
What I find I'm doing increasingly is browsing for album information on the internet while I'm listening. "Who's that on bass?". Are there any other albums where they feature?" etc. I just Google it up. Often (but not always) find myself on the Wikipedia page about the album and/or artist. I don't really need much local information.
I don't often bother with different labels/pressings so that isn't an issue for me. Where I do have two versions e.g. Pearl Jam -Ten, Pearl Jam -Ten Redux, I just edit the album name to differentiate if iTunes doesn't get it.
Posted on: 15 February 2012 by m0omo0
Yes, I'm doing something like this too (with square brackets but whatever).
It's a pity though, because standard (or at the very least "suggested") tags -- either ID3v2.4 or Vorbis comments -- are already there for these kinds of information. It's just most software seem to make no use of them beyond basic artist/album artist/album/track/genre/release date.
It's true that a lot of info can be found online, but I think it would nice to be able to browse the collection through less than trivial criteria (all Hoffman-mastered albums; all albums with this bass player; all albums from Souljazz Records; etc. to your liking).
Coherent information is hard to maintain, that's why I think Naim's decision to go with licensed AMG pro data is a good one.
Maurice
Posted on: 15 February 2012 by spartacus
The All Music Database is used by a lot of people. iTunes, Amazon, Naim, Yahoo!, Windows Media Player. It has a lot of information available from Basic data to Editorial data like biographies and reviews. I am not sure how much of this information is mined and presented by each of the licensees.
I agree with Patrick that some people like lots of this stuff and sometimes I do so to satisfy this need I use an app on the iPad called "Discovr Music" which presents the connections between albums/artists etc in a "mind map" that then takes you to all sorts of new artists and music.
Hmmm... 'About iTunes' says Gracenote CDDB, not AMG or Rovi. But whatever, the number of providers of such information is limited, and I presume Rovi's AMG and Gracenote's CDDB are among the most complete. (I find Discogs, a crowd-sourced database, is good too. MusicBrainz not that much.)
I too would like to know how much is used by which software.
Sure it is easy to find information on the Internet -- be it through apps --, what I would like to have is this information about my own collection. Browsing the cover sheets if you like, and putting this information to good use like in creating playlists, or browsing specific information, or finding correlations I didn't know about. The technology is here, it just seems not to be used which is a pity IMO.
For instance, I've discovered a jazz bass player I didn't know about, Trevor Ware, in a new album I've just bought. I most certainly have other albums where Mr. Ware is playing, and if my CD collection was ripped I'd like this information to be easier to find. This is not public information from AMG, except if stated in some reviews, or if a work is under Trevor Ware's own name.
I don't mind using these types of identification rather than the actual tags.  The reason being that it is a little messy to start showing a ton of tags in clean media views.  There are only so many columns I want to show.
For control points they may or may not (most dont) support things like "Performer", "Composer" or BOTH "Artist" AND "Album Artist", "Bitrate" etc...
Typically, those are:
- Artist
- Album
- Track #/Track Name
- Year
- Genre
Anything else is superfluous for my needs.  So, any info I find pertinent to a release I put in the "Album" tag.  Search features of course find those and they can also be used in Smartlists or other playlists.
For example, there are a few record labels that I always want easily searchable and also in the "Album" tag for quick reference.  Tzadik, Winter & Winter, Anticon, Ipecac, WARP etc...
Also, I insert any bitrate info into "Album" tags so they are searchable as well.  A typical example of an album tag would be:
"Dreamers {Tzadik 7074 - Vinyl 24-96}"
or
"Remain In Light {HDTracks 24-96}"
Then I can set-up active smartlists (playlists) that look for (or exclude) certain things.  I have a "hi-res" smartlist that looks for "24-48" and "24-96".  I have an "Audiophile" smartlist that looks for "Diament", "Hoffman", "MFSL", "DCC" etc.  I have a "Easy Zorn" list that excludes "Naked City", and "Painkiller"
J River's smartlist are super powerful and of course not static, i.e. they update on the fly given tags.
-patrick
Google "tuneglue".  Sweet.
