mobile broadband connection help
Posted by: alancrane on 12 October 2011
I have a unitesever harddisk player i need to make it wifi enable so i can collect meterdater from my network i dont have a landline.
Posted on: 12 October 2011 by Richard Dane
Alan,
if you are using mobile broadband then you can get a box into which you can plug your mobile BB dongle and it will then work like a router.  You then just plug the Unitiserve into the LAN socket of the box.
