Kinsky
Posted by: jonnaim on 23 October 2011
Please would anyone explain what I need to do to use kinsky as my app instead of n stream to control my ndx
Is it easier to switch between the two.
At the moment n stream works fine and I am a bit worried about messing it up by using kinsky
I am not very technically minded so the simpler the answers the better!
Thanks all
Posted on: 23 October 2011 by james n
It won't work properly unfortunately or at least I can't get it to work with my NDX. I did manage to get it to work in a bastardised setup of Chrous DS a Linn ADS and an NDX but not anymore. Shame as it's an excellent control app but I have everything crossed in the hope that the n-stream update will match it...
James
Posted on: 23 October 2011 by Tog
Latest version of Kinsky works quite well with my Uniti - running on a Mac and on an iPhone Tog
