Unitiqute running hot?
Posted by: Nickalexander0703 on 28 October 2011
Hi I have a Unitiqute which is working well but it is always hot to touch, even when no music is playing. Is this normal? Thanks in advance cheers
Posted on: 28 October 2011 by naimUnT
Yes, that is quite normal. Go to factory settings and then System Status to find out the running temperature. The Qute case is used as a huge heatsink for proper thermal dissipation. My Qute runs at about 48 degrees and is hot to the touch. Make sure it is placed on a shelf with proper breathing space for air to flow.
Posted on: 28 October 2011 by RaceTripper
My UnitiQute ran at around 50 degrees. Since I added a 250 and turned the amp section off, it runs at around 40 degrees.
Posted on: 31 October 2011 by Nickalexander0703
Thanks for these replies, really good to know cheers
