Home Theatre Optical Out?
Posted by: JBBY on 30 October 2011
Hi folks
I've an Arcam BDP100 on home trial at the moment.
I've hooked-up a HDMI lead to the TV and am currently drawing the sound from the TV via optical cable to my UQ.
I would like to have the sound run directly from the BDP100 to the UQ though, so I tried connecting an optical lead as I have a spare in this way, but all I get from the speakers is a hiss. I then tested this lead on my Apple TV, same result. So thinking it might be the lead I tested the lead from the TV to the UQ and it was perfect.
Is the optical out of the Apple TV and the BDP100 multichannel which the UQ cannot read?
Or should I use the coaxial output?
Hoping somebody might be able to help.
Jason
Posted on: 30 October 2011 by james n
Set the digital output to 2 channel PCM on your BD player. That'll sort it.
James
Posted on: 30 October 2011 by JBBY
Thanks James, that worked a treat.
Posted on: 30 October 2011 by Vaughn3D
Also, turn dolby digital to off on the atv audio & video menu.
Posted on: 31 October 2011 by JBBY
Thanks for that also.
